Damaged Hull -- Pictures
jbcurt00
Re: Damaged Hull -- Pictures
The transom PB is often a problem. Might try something like this:
You may try to get it cut free before you score & remove 1/2 the splashwell lip. But that area is often covered by trim of some sort anyway because of the exposed fiberglass edge.
Peter9Do
Thanks JB for the cut diagram! Where do you find these things? You're the MAN!
So, I have one favor to ask of you guys with tri-hulls. Does anyone have a picture of their trailer for their boat that they would like to post? Now that I have the trailer out I can do the repairs on that as well, which the frame has been bent and I want to see different set ups for tri-hull boats would look like. Any images would work and the more the better! THANKS GUYS!
jbcurt00
Um, MS Paint. I did it @ 6mo ago for a different thread.
Your welcome...
tallcanadian
I'm not sure if these will help or not. I have a Holsclaw trailer that's a little different than a regular trailer. As far as your transom goes, is it peanut butter or just plain resin. They stacked a lot of resin between the splashwell and transom on my Gypsy. It eventually just cracked and fell out, after a few beatings. Now hurry up and get the top off so I can see that dark rotted transom. Got to see that dress come out of the closet.:D
Yacht Dr.
If your going to trying to debond the trans from the splashwell then its best to start to remove the bond on the transoms side and NOT the splashwell side of the putty. ( normally )
Yes your going to have to leverage and "pressure cut" that thing off.
Be Very careful because sometimes when those things release it can come back to you causing injury. PoP kinda thing ..
Good luck.
YD.
PS. cold chisels and a hammer work sometimes ;) ..
rchapa28
Yep. Nobody eats an elephant all at once. Break it up into small projects that you can take 1 at a time.
1A: relax & breathe as Glenn suggests
1B: find & stockpile a beverage of your choice: frosty, adult libations are preferred by many. Those of us that don't drink, well we choose something else. What ever your choice, you'll need a good, comfortable sitting, staring & thinking chair close to the project as well. You will likely be using both quite frequently.
2: understand that this will be a taxing, frustrating and not inexpensive endeavor
3: know that if you choose to undertake this adventure, it can be done, and can be done well. Many (most) of us had never done anything remotely close to restoration & rehab of an old boat. I had never owned a boat before I built my plywood canoe-thing last summer. And had never owned a 'real' boat prior to Nov 2011. That is not the case now. None are ready to see action again, but that will eventually change.
4: did I mention that this will be a challenging, but extremely rewarding endeavor?
5: understand that no matter your timeline, you will miss goals & deadlines if you set to many or too large a goal. Break it down into small tasks that can be accomplished over a week or a month working a few hours (or 30min) at a time. See steps 1A & B
6: You don't mention what you paid for this boat, but no matter it's initial cost, if you had that money back & added $3K to it, and were able to put all of the money towards a different, more expensive boat, you may in the end still be here facing some difficult & challenging (have I said that already?:facepalm:) work. You will just have a more expensive project boat..... Unfortunately, used boats that have been exceptionally well cared for, are extremely hard to find and not inexpensive. Rehab of an older used project boat also allows you to pay for it over time as your budget allows. Inexpensive boats don't typically qualify for a loan. 2nd mortgage, line of credit, personal loan maybe. So you can buy materials & supplies a little at a time, and stockpile them until the weather in Buffalo improves in the spring, unless you have access to a heated garage or can tent the boat in the driveway & heat it.
7: Watching friscoboater's & boatwork's today youtube videos helped a great deal. In fact, between youtube & iboats, there isn't a part of the rebuild you are facing that isn't covered by multiple videos posted by multiple users. Watching the videos really pulled all the info I'd read & tied it all together with the pix I was seeing.
8: just like taking it apart & working on it 1 step at a time, you'll put it back together. I often shoot pix of portions of my project w/ the tape measure showing, so I have a visual record of details:
9: many of the resto threads start w/ something similar to your last post. some of those are finished, some are never heard from again. More then a few work very hard for a fairly long time & eventually succumb to pressure & frustration and are abandoned via the landfill. Find PMC's ChrisCraft thread, and Bear's yellow Imperial runabout thread. 1 went project tin, the other just traded up to a much more expensive boat.
10: good news grammer & spelling don't count
11: you get to work with your hands, get covered in dust, itch like crazy, buy some new tools, learn some chemistry, and get to say: I re-built that at the launch ramp. Something that many would like to be able to say, me included, and only a few attempt successfully. Or at least as compared to the general boat buying public, our numbers will be small. See steps 1A & B
It's just a boat, it isn't a piano, and they are all pretty much put together the same way. The crew @ the iboats dry dock can help you get your's torn down, taken apart, repaired & put back together.
Take a step back, consider your situation, and give it some time. After a few days, the OH CARP & the feelings of
may subsided & you can start to make a plan to finish the demo. At this point you own it, and it isn't going anywhere. And you are ahead if the exterior hull is in as good a shape as it appears & cleans up 'easily'
Task #1 will be to secure a good work environment, some safety gear & a grinder w/ some grinding disks & a shop vac. See steps 1A & B
Very well said !!
Peter9Do
Thanks for all the help, as usual! TC that trailer is AWESOME! I'm going to have to bend the frame back a little and see what I can make out of this to be more supportive in the proper places to avoid this issue again down the road. As for the cap removal, I have been chipping away at the PB little at a time I ran a strap threw the cap and I'm going to slide it down to the back to add a little pressure to it. I will be sure to keep my face clear of the cap. Thanks again guys!
Peter9Do
Still fighting with the cap... I need a chain saw, something explosive and **** Cheney with a shotgun... That should do the trick!
So, I have one favor to ask of you guys with tri-hulls. Does anyone have a picture of their trailer for their boat that they would like to post? Now that I have the trailer out I can do the repairs on that as well, which the frame has been bent and I want to see different set ups for tri-hull boats would look like. Any images would work and the more the better! THANKS GUYS![/QUOTE]
tri-hull on 89 LoadRite Trailer with bunks. Hope it helps.
Just keep plug'n away, every little step is one step closer to getting done.
sphelps
Just catching back up on your project . Looks like ya headed in the right direction . Cradle looks good and sturdy ! Good luck with the decap .
Btw I like the info on the led lighting . I've been thinking on installing some on mine .
Peter9Do
Thanks for the pictures Plugging Away! I'm kind of undecided on what to do with the trailer. It's so bent and twisted, I'm thinking maybe just getting a new one is going to be the rout to go. My buddy with the frame shop insists on me bringing it to him for him to straighten it out however I really don't want to bother him with it. 60% of the damage on the boat is from the trailer, so either way I want to make sure it doesn't happen again. I think I'm going to do without the rubber bumpers seeing it looks to be more supportive for a V hull rather a tri.
SPHelps, welcome back! Glad you found the LED talk helpful. If you have any questions, please feel free to give me a shout!
IraRat
Peter, I just started following this thread, and all I can say is I salute your courage and determination!
IraRat
http://i1297.photobucket.com/albums/ag21/FM-312/DSCN0008_zpsede35cb6.jpg?t=1363647968
http://i1297.photobucket.com/albums/ag21/FM-312/DSCN0007_zpsfd7e682d.jpg?t=1363734217
Just some info in case you're interested:
If you open a new window with your photobucket images and open the full size of that image, you can right click on it and select "Copy Image Location."
Then, in your posts here, type [/COLOR]
Paste (control + v)
Then type [COLOR="#B22222"]
Note the slash in the second one.
Your images will now appear within your post, and not as just links.
tpenfield
Paste (control + v)
Then type [COLOR=#B22222]
or just click the image icon and paste the image location (URL) in the space provided. It takes care of the "img" formatting for you. . . .
Thanks for the tips Ira, TP
I'm still trying to figure this out, trial & error......
Peter, I'm just a couple hours south of you, It's no warmer here.
I Say Bring On Global Warming!
But wait till we get our boats fixed first.
Peter9Do
I thank you sir! However, this website is loaded with sick individuals that have provoked this madness, and I have to give proper respect to them for my courage and determination. I never would have done this if it wasn't for them!
jbcurt00
Let me add, I curse their names daily!
Um, thanks.... ??? :D ???
