Re: Dash panel installed
Thank you all.<br />RodC no, no drawings for me what I did was use the correct color codes. then hooked up all negatives to bus, then hooked up 1 positive at a time and tested.<br /><br />The bilge pump has 3 wires 1 is for the float and 1 for the switch. Negative was already yellow and grounded. I then took the wired up positive wire and touched it to the posative bus.
Yes on the fuse side. When I heard the motor I knew this was the switch wire the other brown was wired to the same post as the switch positive behind the fuse so both are fused and powered. I actually blew a fuse as I was using a 2 amp to do this knowing what could happen.<br /><br />I then had to undo all the wireing to take out the broken panel and replace it with the polycarbonate 1.
<br /><br />Oh all wires are crimped except the big 6 guage I wired to the fuse block. Gotta get the hang of the big wire crimper is all.<br />All other big wires are crimped now that I know how to do it correctly.
