Purduebarry
- Sep 29, 2005
- 378
This is the checklist I've created from various sources...I have a manual in route, but I trust the forum as much as the book, so please let me know if I left anything off or have it all wrong.<br /><br />1) Marina winterized and performed top tier service - Changed drive lube, Oil & filter change, Fuel filter, Fuel stabilizer, Fogged the engine, disconnected all water hoses, removed two manifold caps and two drain plugs.<br /><br />2) I plan to replace all hoses, the manifold caps and the freeze plugs.<br /><br />3) I plan to Tune up the engine - plugs, points, cap, rotor, timing, condensor etc.<br /><br />4) I plan to replace intake impeller (preventative maintenance)<br /><br />5) What about Seafoam? Use it or loose it?<br /><br />6) Was told to lubricate the u-joint on the drive? What does this entail? What lube should I use? Or is this not necessary?<br /><br />I'll top off the tank with some Premium, take it too the lake and... anything else? Just start it and go? This is my first de winterization with this boat. Thanks!
