I've got an inboard 318 in an old Penn Yan. It's been running like a top. Went out yesterday, shut it down for a few mins, and then nothing on start-up, not even a click at the solenoid. But I can jump the starter, so it's not that.
This morning I replaced the ignition switch, solenoid, and coil. The battery is new and fully charged, and even with the jump assist from my charger.....nothing.
I've loosened and cleaned every connection and ground I can find. Checked all the fuses and cleaned all connections in the fuse panel.
Any suggestions on where to troubleshoot next?
What voltage should I see on the two small posts on the solenoid when keyed? Right now I have zero on each.
Thanks......
Thanks......
