Dead injector?
alldodge
The injectors have replaceable screens and they start to rust from the ethanol gas. I would have them cleaned and flow tested
1990dtgl98
I bought oem reman injectors. I'll send mine out to get cleaned and flow tested.
I would up seeing rust in the regulator housing so I'm not sure how bad everything is. I blew it out as best i could but the lines are NLA and unless I'm taking one from a junkyard, spending 500 on a used set online is a crapshoot.
I'll probably run it for 2 years and the ones I sent out to flow test ill swap back in and see how.much new rust is in the screens. Im.hoping I got most out of the housing and what I see is just surface pitting that won't slough off back into the screens.
