Tonight I had nothing better to do than tear into the mess of an engine I have. I decided I would AT LEAST disassemble it and see if it could be rebuilt, and possibly even go thru with it (if I can't find a cheap comparable outboard anytime soon).<br /><br />First things first, flywheel removal. Guess what? I dont have a puller, and no one in town had one for a marine flywheel (I tried a steering wheel puller, didn't work.). So, I had to make one:
<br />Simple, but effective!<br /><br />After that, I got the rest of the engine stipped without much hassle at all. I had one screw/bolt that was locked up on me. Luckily, it was in the exterior shroud that covers the lower exhaust manifold. I broke a little piece of the lower engine cover off trying to get the screw loose, oh well, no big deal.<br /><br />After about 2 hours, I had the powerhead ready to be pulled. I went to pull it/break loose the gasket on the lower end of it...and I couldn't get it to move for a bit. I checked, checked, and triple checked to make sure that there were no more bolts anywhere holding it down. I re-read the manual I have, and it said '4 bolts on each side, one stud with a nut on it'.<br />I could only find 3 bolts per side, and the stud on the back of the powerhead...<br /><br />Is this thing just sealed on there that well, or am I missing 2 bolts somewhere? Anyone know where the mystery bolts may be on this engine, or do I need to call scooby and shaggy? <br /><br />Or, if it is just sealed with age (1972), how should I seperate them?<br /><br />I tried using pry bars, rubber mallets, etc...it wouldn't move a hair.<br /><br />Thanks in advance!<br />Shawn
