Deck coating / Turned complete restore
Status
Not open for further replies.
ahmincha
Re: Deck coating / Turned complete restore
Thanks gt I did watch that awhile back great sound track you added and did plan on revisiting it before I do mine now I do not have to search
ahmincha
Csm on top and half way down the sides when that dries I will do other side
ahmincha
fuel tank bulk heads one coat csm
Woodonglass
Hey, what happened to all dem dere Air Bubbles!!! What's up with Dat!!! You gettin better or sumthun!!!!:confused:
ahmincha
The flats look pretty good the small 1x cross boards have there share of air bubbles. But I figured where they are placed and being as the originals had nothing I am not going to get nuts over it
ahmincha
fuel tank strap Plywood the fuel tank will sit on
Woodonglass
You're really layin down the glass today!!! Go Man Go!!!!
ahmincha
Yeah I lied a had to grind the glass off the cross braces I just cant get them tight radius's. Now I see why the factory didn't do them haha
Woodonglass
Are you tuggin and pullin the glass to loosen it up a bit before you try to lay it over the radius?
ahmincha
No I forgot that trick you told me about I will try it again tomorrow Thanks again
ahmincha
I have this in spots on my dried fiberglassed pieces its not as bad as it looks in photo I super zoomed. These are the gas tank bulk heads that will be tabbed in with 2 coats of 1708 over it. What is the cause and in this instance can I go over it or does it need redone. It is not raised
Woodonglass
I don't say this very often to newb's but...More Resin!!!! It's dry on top. Maybe due to over rolling it.
Let's review.
Coat the wood with resin. Once it's Tacky Re-Coat with resin and then lay the mat on top of the wet wood and roll the mat into the wet wood starting from the middle and work towards the edges. I like to use a bubble roller to force the resin into the mat from the bottom up and work out air in the beginning. I then use a short nap roller to roll additional resin into the mat from on top again from the middle out. Once the mat goes Clear I stop. No more rolling necessary. No more figeting. Nada!!! Done!!!
I'd roll a thin coating of resin on that and call it good.
GT1000000
I agree with Woody, looks too dry...if you can pull up that corner I see in the upper left...I would guess it isn't sufficiently protected against water intrusion...
Hopefully it is no too much real estate that is like that, but it seems to me that it would definitely be a candidate for being redone...
If it is only a section of it that looks that way, you can just grind the bad away and re-do that section only...
Follow Wood's procedure^^^^above and you should not have any further issues...
Oh and don't feel too bad, I have had my share of "Failures to properly laminate"...all due to errors on my part...
Carry On!:D
JASinIL2006
That's what mine looked like when I wasn't wetting out the wood sufficiently before applying the glass. In my case, I think the wood sucked up the resin and left the voids. I started letting the resin soak in more, in some instances lowering the %age of MEKP to slow down the curing process so the resin could penetrate, and it stopped doing that.
ahmincha
Thanks gt yeah its only about 2"x2" section ill grind that out redo Looks larger then it is I super zoomed so you guys can see better.
Thanks jas I know you guys are right I will slow down a little and let the resin soak in better. I was actually wetting it out with resin and basically adding my csm trying to go to fast
ahmincha
Good news is these came out better then the small ones so I still got some forward progress
ahmincha
Had to cut fuel tank board down for height Now I just make it with floor but nowhere to bolt my straps to plywood fuel floor Will front to rear straps be sufficient any better ideas I am at a standstill till I work this out
ahmincha
What do you guys think of brackets from above
NicoPags
Would look great with the straps over top. I must say I'm just coming across this thread and I've taken many great pointers from you folks. Will you fabricate some way to still have access through the deck?
ahmincha
The lines in red represent the cross braces that carry the deck. Would sandwiching blue foam strips under them work to hold the fuel tank in
Status
