Deck coating / Turned complete restore
Status
Not open for further replies.
Woodonglass
Re: Deck coating
Re: Deck coating
If the drawing on page 3 depicts where the tank truly is, then those can't be "Boxed" stringers. They have to be more like 2x or 1x 10's or 12's laying on top of the foam and tank. The pic shows the tank underneath them. I guess they could have cut the sides out to accomodate the tank at that juncture. It's hard to tell with all that foam in there. One of the previous pics does show the bulkheads looking like they are a box type construction so it's possible the longitudinal one's are as well.
th
Velly Intellesting!!!!!
ahmincha
Re: Deck coating
Re: Deck coating
Yes wood you are correct those are 1x10 or 12 sitting on top of foam. With fiberglass down to hull but no wood vertically just the fiberglass same in the bilge area no wood I am going to try to get foam out tonight will post more pics
Woodonglass
Re: Deck coating
Re: Deck coating
Well it might LOOK like fiberglass but it could be Wood encased in woven roving fiberglass. Are you saying there is a Side Vertical Wall extending down to the hull on the sides of the 1x10-12??
ahmincha
Re: Deck coating
Re: Deck coating
Yes down the center of the boat I am assuming you call that the bilge area front to rear there is woven fiberglass that goes from the 1x to the hull about 10" and there is no wood on either side.
ahmincha
Re: Deck coating
Re: Deck coating
Red lines there is no wood deck down to hull just wooven yellow is wood covered in woven blue seems to be just plywood with no fiberglass at all same around the complete fuel tank. I did not get to work on it last night will update tonight
ahmincha
Re: Deck coating
Re: Deck coating
Thanks greenbush future My plan is to replace all the foam and your right the foam is not horably wet but it is wet and if I am this far I might as well do it all. I am not all the way to the transom quite yet but as of now it seems solid fingers crossed
Just a little jc but the lights and heat are on you can come on up
ahmincha
Re: Deck coating
Re: Deck coating
The area within red circle is the woven fiberglass without any wood backer this is the area under the 1x12. The green area is the bulkhead in front of fuel tank
ahmincha
Re: Deck coating
Re: Deck coating
closer picture of the 1x12
ahmincha
Re: Deck coating
Re: Deck coating
These 1x3 run from port to starboard and the 1x12 sit on top no wood down from 1x3 to hull
ahmincha
Re: Deck coating
Re: Deck coating
only plywood vertically is around tank
ahmincha
Re: Deck coating
Re: Deck coating
Do you guys think I should remove these storage areas
ahmincha
Re: Deck coating
Re: Deck coating
Foam was not to bad but its all coming out to put in new. My new question is I figure my best plan of attack is to get all the floor out in the rear picture in post 91 I assume if I cut these 2 storage areas out close to floor transom and gunwales I should be able to re tab them in any thing I should be concerned about
jigngrub
Re: Deck coating
Re: Deck coating
Just be careful and take your time cutting and you should be fine.
jbcurt00
Re: Deck coating
Re: Deck coating
Yep, probably. Cut them free right in the corner, keeping the blade parallel to the hull so you don't dig into it.
As before though, you'll need to grind back the brushed on white coating inside & outside of the boxes to be able to tab them in. Same for the hull sides where they attach.
ahmincha
Re: Deck coating
Re: Deck coating
Ok one more question I want to cut the lower section forward and the upper section back to one level more deck room. Do you guys think I will have strength issues with the gunwales moving the lower section forward
ahmincha
Re: Deck coating
Re: Deck coating
Hello everyone
When I go to put back the foam is 4 lb the right density to go with and do I use the same around the fuel tank
ahmincha
Re: Deck coating
Re: Deck coating
Thanks jb and jig I will read those links. either of you guys or any one else have a answer to my question on post 95
jigngrub
Re: Deck coating
Re: Deck coating
How far do you intend to cut the bottom deck back, 2'?
Status
