Deck coating / Turned complete restore
Status
Not open for further replies.
ahmincha
Well I have all of you guys to thank without the help I received here it would of never even been attempted
ahmincha
Ok last one and I'll stop boring you guys In the beginning of the video way in the distance is the Cleveland skyline
friderday
so happy for ya....check your pm, minch....I sent you one the other day(I know, I know...you've been "busy" "boating" lol)....Interested in that light....
tallcanadian
There is no such thing as a boring boat video. Congratulations on the splash and good luck. You done good....
GT1000000
Phil Collins in the background, wide open water all around...man oh man..."I can feel it comin...hold on"...yeah buddy! Suh-Weeeet!
Congratulations! you done yourself proud! Beee-U- tiful!
May you and yours enjoy many, many hours on this fine craft!
Godspeed and smooth sailing!
Corjen1
AWESOME Mincha!!!!!! Congrats!!! very cool to see her on the water!!
ahmincha
Thanks guy's it was a great feeling and it ran great I am looking forward to seeing all of your splashes.
Bob I also have a suzuki and I really like the way they run
ahmincha
Question I have is can one shifter run 2 motors forward reverse and throttle
GT1000000
You would have to get cables set up similar to a multi-engine or fly bridge...but I would suspect the throttle opening and shift points would be different for the two different motors causing some problematic throttle and shift responses...
Another extreme possibility would be to fabricate something like a 4 speed shifter from a car into a sort of dual controller, first and second would be engine one, forward/reverse...3rd and 4th would be the second engine...might need separate throttles...crazy I know...:crazy::peep:
To avoid problems, you might just have to hook up the second controller in front or behind the other...maybe even be able to "stack them one next to the other...???
Be interesting to see what you come up with...:)
ahmincha
So what I did was buy a top mount control it works 2 motors separately ran the cables and I can shift and go from the helm on both motors. The nice thing about this control is it accepts all cables. Then for the steering on the 9.9 I went electric
GT1000000
Perfect solution, minch!
You got yourself a winner there!
Thought didn't even cross my mind about a dual controller...
Can't wait to hear about it in action...
Nice!:D
ahmincha
Ok hopefully someone may know my boat is self bailing . I want to leave it in the water a couple nights . Just sitting in the water it takes on a little water on the deck . So if it were to rain would it keep filling up or will it only takes on so much then drain
GT1000000
To the best of my understanding of basic water physics...
As long as there are sections/pockets of the boat that are isolated from the water, the body of water the boat is in can only rise as far as its own level in the boat...if rain water can fill the isolated sections, and it becomes enough to swamp the boat, then it could sink...that is one reason to have a bilge pump connected to a float switch directly to the battery, although if it runs long enough trying to keep up with the water coming in, it could drain the battery and stop working...
This was a sketch I made showing how a live well in a boat that is open directly to the body of water will only fill to the level of the body of water...as long as the rest of the boat stays dry...
In the sketch above, if rain water is able to fill the area in the hull that is isolated from the live well and the bilge pump cannot keep up, it can sink...
In a self bailing deck, my understanding is that the rain water will become part of the body of water as long as the self bailing feature of the hull does not become plugged/blocked or clogged preventing the rain water from escaping the boat and the remaining water-free air chambers in the boat remain intact and relatively dry...
Similar to this sketch I found...the image won't load, but here is a link to it...you might have to copy and paste or if that doesn't work google "self bailing" "Images"...
https://www.google.com/search?q=sel...rentPage%3DshowAll%26module_id%3D232;1000;720
Sorry, not exactly a very scientific explanation but its the best I can do...:redface:
jc55
Nice work! Does your kicker maker your boat list hard to port?
ahmincha
Thanks gt that is just scientific enough any more and you for sure would of lost me
I wouldn't say hard but you do have to pay attention where people sit And thank you
jc55
I was curious because it looks like we have the same scuppers. My 9.9 makes the boat lean, and I've had to plug mine.
Status
