Degree symbol ??????
fat fanny
How do get the degre symbol behind a digit ? I have been trying to figure this out for years but have'nt had the courage to ask. Every ? gets answered here.
bruceb58
Re: Degree symbol ??????
[alt key]0176
do it using the numbers pad on the side of the keyboard
or
cut and paste it
or start>programs>Accessories>System Tools>Character Map
fat fanny
69? wow it only works with the alt 0176 method now I can die with a smile on my face that has had me by the short ones for over 10yrs. thanx bruce58?. This should be a stickie I wish I had a dollar for every discussion involving timming and the sysmbol isn't being used or something in it's place. I nominate bruce58? as I-boater of the month
[alt key]0176
Ayuh,... That's what I do....;)
Hold the Alt key, 'n type 0176 on the # pad.... ? :D
scipper77
my laptop doesn't have a numeric keypad so I have to cut and paste from the char map. When I was in college for engineering I memorized Alt+0176. You use it a lot.
cribber
? Just a quick tip if you're using a laptop (mine is a dell) with an embedded numeric pad in the keyboard. Hold down the Alt key along with your (usually) blue function key and then type 0176 using the embedded number keypad.
scipper77
? Just a quick tip if you're using a laptop (mine is a dell) with an embedded numeric pad in the keyboard. Hold down the Alt key along with your (usually) blue function key and then type 0176 using the embedded keyboard.
I always wondered why I have a num lock if there is no num pad??
kenmyfam
Copy or cut and paste for me................90?
DECK SWABBER 58
So.........now what exactly is the temperature in Ohio? :p
joed
ALT 167 = ?
ALT 0176 = ?
What's the difference? They are slightly different.
JRJ
Currently 75 here and the ALT167 doesn't do a thing on this laptop :mad:
