I have a Delco EST distributor that has two plugs. Left plug harness goes to the ignition coil. Right plug/harness has 4 wires. There is a special 3 wire harness for engine timing. On this plug, wires 1 & 2 are jumped together; wire 3 is connected to 12v. The 4th wire goes to the shift interrupter. The regular plug has only the 1 wire that goes to the shift interrupter.
I am not sure if the wire that goes to the shift interrupter is the leftmost or rightmost of the 4 wires. Any help you can provide is appreciated.
Richard
Richard
