Re: Dennis Moore performace Books
Tell ya what Stan, I'll ask tomorrow, if they have another, it's yours for cost + shipping.<br /><br />There's a few problems on pages 192 and 193.<br /><br />I'm sure they're misprints but, the V8-22 and V8-22a are mislabeled, switch the "a". The V8-22 is 22 degrees at 3,400 rpm, the V8-22a is 22 degrees at 4,400 rpm.<br /><br />Also, under the V8-24s, between the 8.5 and 13, there is an 11 or 11.5 missing, step all the numbers down one to fit the 11 in, then change the second 23 to 23.5 and make the original 23.5 a 24. The V8-24s is 24 degrees at 4,600 rpm. For the time being, I'm only looking at the V8-22a and V8-24s, but, the 94 350 Mag calls for 32 degrees at 3800 rpm. The book says it uses the V8-24s. They don't match. Hmmmmm......<br /><br />That may not be perfect, but the curve looks wrong, I'll keep digging.<br /><br />The Delco curve on the next page looks like it's way off unless they're counting (or not counting depending on how you look at it?) vacuum advance, which would be pulled off at lower rpm.<br /><br />Did that make any sense?
