Destroyed Prop... need advice
derekb95svt
Over the weekend I was haulin *** down the river (which by the way is lower than normal thanks to the drought) and hit a sandbar. No damage to anything other than it chewed the porp up real bad.
Anyways, I am looking for advice on getting a new prop. I have a 1989 ArrowGlass 23' cuddy with a Merc 5.7 Alpha1. Since it is used for cruising the river I need something that is durable and good on performance. Any suggestions?
Thanks in advance
Haut Medoc
Re: Destroyed Prop... need advice
You will get better answers in the prop forum....;)
180shabah
Ditto.
But since you are here, after plowing through a sand bar, it would be a good time to replace your raw water impeller.
f_inscreenname
"that is durable"
Better your prop take damage then your outdrive. Just think of them as a crumple zone for your Alpha. :D
Don S
Lets move this over to the prop forum.
