- Mar 8, 2009
- 43,634
If you don't want to use it, why come on here and even ask the question?
The OP has received different opinions, he just didn't take yours, it's his boat
LOL...everyone said to stay with Dex-Cool...even you. Yep, his engine.I would stick with Dex...
Yep, was determined it was bad gasket material. When they redesigned the gaskets, they no longer had the issues. They realized that it didn't matter what type of coolant that was in there that the gaskets would have failed. GM had a lot of problems with that engine yet didn't have the same failure on other engines that used the same DexCool. My parents had the same 3800 engine in an Oldsmobile and never had an intake manifold problem but my dad would change his antifreeze fairly often.Here is an interesting read. Interestingly, the two issues I had with intake gaskets, were both the GM 3800, with Dexcool in them. One a 96 and the other an 03, the same year as our Cruisers.
http://www.dex-cool.net/
Your 8.1 would never have the same issue since it doesn't have a coolant passage in your intake manifold.
BTW, Ford and Dodge use almost the exact same coolant and you probably have it in your Ford 6.8, or you should. It is an HOAT type coolant which is almost exactly the same as the DexCool spec'd fluid. Their fluid is spec G-05.
I would call Crusader up and see what they recommend. Can't get any better recommendation than them.
Good video.Here is an excellent video. https://www.youtube.com/watch?v=Ffpe8aVvb2c
Good video.
Bottom line. Call Crusader and ask them what they recommend.
I use the Prestone or Valvoline antifreeze that meets the spec. Same goes for your Ford truck engine. You just need the antifreeze that meets the Ford G-05 spec.GM or Crusader have never manufactured antifreeze. GM pays someone else. [Used to be Texeco, not sure if it still is] Does this mean someone else cannot come up with a better formula? Not a chance...
