Did I just destroy my new Coil????
boatingedge
I am tracking down a no spark issue and believe it is either the coil, ignition module or high voltage lead. As part of my testing I replaced the coil. When removing my old coil where the high voltage boot goes on, the screw came out that was in the middle of the coil terminal. Thinking that the screw needed to come out of the new coil to secure the lead down, I removed the center screw from the new coil. I then realized that the reason the screw came out of the old coil was due to the high voltage lead being corroded to the old coil terminal. So I put the screw back into the new coil.
By removing the center screw, did I break the new coil?
Is there a way to bench test the coil outside the boat?
Thanks
1994 - V-8 5.0L thunderbolt IV ignition system
cheburashka
Re: Did I just destroy my new Coil????
Shouldn't be a problem. On an oil-filled coil, that screw is the fill hole for the oil. I don't see any reason why it shouldn't go right back on.
