guy48065
- Aug 31, 2008
- 554
Seems to be used all over the electricals in cars & trucks but I'm not seeing mention of its use on boats.
The 2000 bowrider I bought this month has been plagued by some electrical gremlins which I've traced back to corrosion on the fuses and push-on connections to the fuse block.
Today I replaced that block with a new unit, new fuses, new SCREW terminals for every circuit.
I dabbed dielectric grease on the stripped wires before crimping. Dabbed it on each fuse. Dabbed it on each screw terminal.
On testing everything works perfect. Radio problems gone. Tach is accurate & doesn't wander.
Did I do the right thing?
I believe there are some unsealed butt & bullet connectors back in the engine compartment that might need this treatment. AND some heat shrink cuz it's even nastier in there compared to behind the dash.
