Difference in 29 sportster models
54bobby
Guys, what is the difference in the 1969 25 hp evinrude sportsters? i have a 25902B and was just given a 25902D. Are they identical? Both are pull starters and short shafted. Nothing visual to me making them different.
54bobby
that's what i'm trying to find out. what were the changes?
Rustywrench
No listing that you can obtain. Could be anything from a vendor supplied part change to an assembly procedure change the factory deemed necessary to note. Most of the time not something to concern yourself with. If different parts are used then it will be spelled out in electronic parts books (usually)!
F_R
If you really want to know badly enough, sit down with the original parts lists and compare everything. Non-original parts lists may show the superseded part and you'll have a hard time finding it. Frankly, unless the part was a notorious trouble-maker, it isn't worth the effort.
jimmbo
1969 was the first year for the 22 cubic inch 25hp. There was bound to be revisions
