different spark plug?
dfrants
what is the main difference between QL86C and QL77JC4 ?
6hp Johnson J6RICOB
Joe Reeves
Re: different spark plug?
The numbers of 77 and 86 indicate the heat range of the spark plug. On that 1985 6hp Johnson, stick to the QL77JC4 plug.
seahorse5
6hp Johnson J6RICOB
As Joe said, it is heat-range along with plug design. If you troll or run at low speeds a lot, the QL86C is recommended. It is more foul resistant than the QL77JC4
