I have a 2000 Merc 40hp 4 stroke ELPT outboard. I've used it twice since purchasing it from a boat center that supposedly changed the oil before putting on sale.
I've used the boat twice....probably running time of 3 hours or so combined.
I just got around to checking the oil myself and noticed that it is a good solid 2 inches above the full line of the dipstick. It also smells different than motor oil that I'm used to smelling. I can't verify that it is fuel for sure, but my guess is that it is. Also, when I pull out the dipstick, the oil drips off the stick a bit more easily than I would think it should, leading me to think that it is diliuted.
First off - what is the deal? Is this a big problem.
That said, I am reluctant to use the motor until I change the oil. Should I change the oil myself so I can establish a baseline and see what happens from there? Or should it go straight to the shop to test for leaks, etc?
Any advice is welcome.
Thanks!
Thanks!
