Okay, i just picked up a 94' 16' Starcraft Fishmaster with a 2004 50 hp Johnson. However, the motor is "locked up"
. I have been told that a power head from a 1981-89' and a few others will replace it. My buddy happens to have a 1984 Johnson/evinrude power head that he says runs but there is a crack in the intake manifold (he offered it to me for free
). I am not experienced with rebuilding outboards but i am somewhat mechanically inclined. Therefore, my question is..can i simply replace the new power head with the older with no issues? I have not taken the newer motor apart yet. Is it possible that i might need to just bore the cylinders and get larger pistons? It was not my outboard when it froze up but i was told it "always ran great....then one day when it was being flushed it just shut off and that was it". The top cylinder has signs of what i guess to be "metal"...looks almost like corrosion....same thing on that cylinders spark plug. The lower cylinder looks fine from my inexperienced eyes and its plug looks like it should. I have been told i can part the 04' out. Which direction should i go? What first? If my friends power head is a direct bolt on.....wouldn't that be the best path?
Thanks in advance, Bleubeans.
