Discount code
jbcurt00
Should be. Did you try to use it and it didnt work?
Banner is still active on my Android for the Forum members save 5%
alldodge
Yep, didn't work. I have a $260 order was going to place and it didn't work. Have 16 or more hours so I can wait
Also tried forums5 and boat10, none worked
GA_Boater
It's on the Forum Home page, AD. It may have changed to FORUMS5.
GA_Boater
Call the Customer Support number at 1 (800) 914-1123. The discount code should work and the CS folks can pull up your order to apply the discount.
alldodge
Well its still listed as a discount, BUT........ it ended last year.
False advertising
iboats_tim
User
Hey AllDodge give FORUMS5 a shot one more time and it should work now. It looks like someone messed with that discount. Sorry about this
Thanks for the heads up jbcurt00
alldodge
Just to be sure I understand this, you called and a CustServ rep told you that it ended?
iboats_tim
Yes, think her name was Jackie but would not swear to it. She found my order, then put me on hold, came back and told we its over, and they were sorry
alldodge
Just got a call back from Jackie and says forums5 is active, going to try it again
alldodge
Took a few tries, kept having "internal server errors".
Was going to buy it anyway to support the forum, only reason I didn't all ready have bought was because I closed window and had to bring my cart back up.
GA_Boater
It finally worked, AD?
There was some miscommunication. Thanks for letting us know. Sorry you had troubles.
