Hey guys. I am planning on fabricating a swim platform for my 2000 bayliner 2150 classic.
It has a problem. The transom of the boat is not flat from top to bottom..
and here is the water line
so i can see myself running into problems with bolts/mounts for it. I am pretty sure i will need to use 4 mounts, 2 smaller ones on each side, larger ones in the center. I am pretty sure i will also need to hinge the center of the platform for the outdrive to come up all the way.
I am also thinking of mounting the platform a little bit higher up than the current one is (maybe an inch or two) using spacers.
anyone have any suggestions, ideas, or thoughts on this?
TIA!
TIA!
