TBarCYa
- Apr 13, 2005
- 781
Re: Do you change prop in the water???
I'm not sure about your prop, but if you have an interchangeable hub you should carry one of those as well. The hub kit contains all of the parts you will need for the job but only if your prop uses interchangeable hubs.
Along with the spare parts, I have a floating prop wrench that I keep on board at all times. Not only does it float and fit the prop nut, but it's also got a hole cut into it for tightening and loosening the bilge plug if you've got the screw-in type.
