swift1
- Jul 15, 2009
- 29
How do you know when a gimbal bearing needs replacement? I pulled into a public dock over the weekend and some guy said that mine needed immediate replacement due to the noise it was making. I couldn?t really hear any noise other than the engine, but he said he heard a ?whirring? noise that was definitely a bad gimbal. While heading back to my dock, I listened for the noise he was referring too, and I was able to make out a sound that could be described as whirring, that became higher pitched as the throttle was increased. At idle there was no noise that I could make out other than the engine. Later, someone else told me that turning the steering from left to right would intensify the noise of a gimbal that needs replacing, so I tried that, but there was no difference. My manual says to remove the drive and see if there is any play in the gimbal, which would indicate it requires replacement. Before I try this are there any other ideas as to what I should be looking for as a source of this noise? 97? Mercruiser 3.0 with a SEI sterndrive that was installed last season(Alpha 1, Gen 2).
