crashkaloop
- Jun 5, 2013
- 54
Although I thought the Ranger 360v I just bought was a 1989, I just found out it is 1987. This only matters because they stopped using wood in the transom sometime in 1988-89, and this pertains to my question.
While installing a transducer on the bottom of the transom, I noticed that the wood was wet/moist. This got me concerned that I might have a rotten transom. I have read many things on this here, and other forums about this subject, and believe the following:
1) That most older boats with wooden/glass transoms do have moisture.
2) That moisture does not mean the wood is rotted or that the transom is unsafe.
3) That a common way to test the transom is to use the outboard as a lever to see if the transom deflects.
4) Tapping the transom with a hammer will indicate a hollow sound if the wood is bad.
So, after performing number 4 above, and finding all seemed good, I did a very precise test of the transom deflection using the outboard as in number 3 above.
I placed a micrometer on a base in the well just in front the motor. With the motor tilted all the way up, I hung 200 lbs on the cavitation plate. The transom only deflected 35 thousandths of an inch. I could get it to go to 50 thousandths if I bounced the weight up and down. (by the way, the weight was me)
There are no signs of any cracks or anything to indicate the transom isn?t anything but 100% ok, but I wanted to see if my testing bears this out. Can I just do a similar test once in awhile to see when the transom has a problem? Or should I find some way to dry out the wood?
Thanks for any comments.
