Don S
- Aug 31, 2004
- 62,321
Re: Does upgrading from points to electronic distributor help?
I looked at your old posts and you have a Volvo AQ290A, just curious, did your points ignition actually have the ballast resistor installed? Without it, you would be changing points every month.
I did the upgrade recently and for the moment the only huge change is the starting and the initial timming setting was perfect and has stayed that way. W points every other day didnt start hesitated and so..
I have no real data to say that it uses less fuel runs more etc etc but with being able to turn the key and start w no problems thats the big deal
Points where changed 3 times in 3 months and never helped, for whom thinks they lacked of maintence
