tredragon
- Jul 2, 2008
- 122
So most of my problems of late have been solved (stuck in gear... fixed... bogs under load in gear on water... carbs tuned... great...)...
However, yesterday on the water while trying to back off trailer (my trailer tilt cable is busted and pin is froze)... and also a few times while trying to adjust by reversing hard... the unit rose up out of the water then banged back down. I see the "dogs" (I'm borrowing a term from Deadliest Catch...) that kinda overlap the tilt pin on my unit... I see that they'd do a great job keeping the motor off the transom in forward... however, they are spring loaded and seem to run to a shaft that runs downward towards the LU... Are these dogs supposed to lock onto the trim shaft/pin at some point so avoid the unit from raising up out of the water? If so... what do I need to do to get them working? I essentially have nothing but very low RPM reverse without the unit flying up out of the water.
