hello<br /> man I got a delima.<br /> while resealing a bravoII the other day at a place I contract for I was removing the shift shaft assy when the owner walked by and asked why I was removing it for just a seal job. I politly told and showed him in the book the only way I could time the driven gears I had to move the shaft out so I could see them. his reply was that the one he did a few weeks ago had no timing marks and he had never heard of them. then later when I was pulling the seal carrier from the lower to remove the load ring he asked again what I was doing and said he never pulled the ring cause he could just pick the oring out and replace it. he had never heard of a load ring. he did not replace it on the last one he did either.<br /> I know the customer that he did this drive on. now I have to try to determine will it make a difference or should I call him and tell him his drive may be at risk.<br /> the owner has maybe 5 service manuals in the whole shop. and he is a volvo,mercrusier,PCM dealer.<br /> my question is have you ever seen the upper case on a bravo run any time with the gears not timed ?
