Speakers: 4x Polk MM651 (2.7ohm, max 100w RMS)
Speaker Amp: MB Quart NAU460 (4x60w RMS)
Sub: Polk MM1240 (425w RMS)
Sub Amp: Hifonics Brutus BRZ1200.1D (450w RMS)
I've adjusted the gains so that max volume is just under distortion level. I estimate the speakers getting 85w RMS each (low resistance) and the sub getting 425w RMS.
At this point, just the speakers are in and I have not installed the sub. The power setup is 20' of 4awg line for hot and ground that each run to a separate distribution block. The block splits into two outputs that accept 8awg line (the hot block is fused on each line). This is the kit that was used: http://www.onlyinboards.com/AccessoryShop/Products/Electronics/Roswell-Marine-Amp-Wiring-Kit.aspx
So, I have about 2' of 8awg line from the distro block to my speaker amp. This setup is running fine with no issues. My question is, when I add the sub amp, am I going to run into power problems using 8awg line off the block? Is the 20' of 4awg sufficient to power this system, or will the sub need a dedicated hot line?
