Re: Down under rebuild of 90HP Force
wow, some great tips there guys!! the exhaust port chamfer is one thing Id been wondering. Its something that is essential when porting the exhaust port on a Rotary motor for much the same reason. We talking a 1-2m radius edge? Might have to see if there is any vids on u tube or pix on the net.
Great tips in regards to the crank aswell, before even dropping mine in I have to install new sealing rings cos I broke them trying to take them of the crank whilst it was still in the case ( idiot, I know). Got 2 sets aswell incase I snap one as I slide it on.
New wrist pin kits and big end bearing pins will be used, existing big end cages tho. The main journals have been left alone, top crank bearing has been supplied in my kit and i will probs have it pressed on the crank even tho the existing seems ok.
In my kit I got some spaggetti seal, but my power head didnt have any in it, Im assuming its for my lower unit or maybe another Force model that does use it?
I also watched this vid in relation to the wrist pins:
Outboard Rebuilding - How to install a piston onto a connecting rod - YouTube
this made it quite clear yeh? I will have to punch out the standard pins from the assemblies first, and with 2 off the 3 pistons being ornament use only, I hammer and punch will suffice, taking care of the rod is my only concern.
many thanx!!
many thanx!!
