rolmops
- Feb 24, 2002
- 5,672
Re: Downrigger set up help
As for distance between ball and flasher. It is not so important. It is way more important to have your lure or fly somewhere between 17 and 20 inches away from your flasher while trolling at a speed that will give your lures the right kind of action.My trolling speed is usually around 2.3 in early spring and as the water gets warmer I speed up to 2.9 or even 3.2 (this speed at the ball,not GPS or water surface speed).
In Lake Ontario it is often hard to work stacked lures at the right speed because of different currents at different depths. It works a bit better when the lures are within 10 feet of each other.
As for the easy-troll, forget about the easy part.Manually raising a 10 or 13 pound torpedo is very hard work. Also, since you have a single down rigger you should try to get it at "six o'clock" the bow being "12 o'clock", because your boat will try to pivot around any single down rigger sticking out to the side of your boat.
Good luck.
Most releases are made for bigger than 12 inch fish.The solution is a rubber band You can twist the rubber band around your line and stick the other end in the release.The hit will make your rod tip dance and that way you will notice.If the fish is bigger it will simple pop the band out of the release or snap it.So I got it set up and took it out fishing. I need to work out the details of how to operate it with the line release, seems like that will be the most challenging. I am using a cannon release. Does anyone have a recommendation as to how to set this for trout in the 12 to 14“ range? Do I put the line in the middle or near the edge?
I didn’t catch anything on it but I believe I got two hits. The line popped out of the release. I am not sure if this is the correct way of rigging the release bu I let out about 30 feet before hooking it to the release, I think this may be why I missed the fish. How far back should I fish my flashers from the weight?
Good luck.
