greener14519
- May 4, 2013
- 13
Hello folks. Thank you for posting some great and helpful information on this forum! Here's a question to anyone who can offer help. I have a '90 Chap with twin Volvo 431 powerheads. The outdrives are DP-A's and on the ID tag each unit says 2-30 and the S/N's are 3102102214 Port and 3102102218 Starboard.
Back in the fall, when I pulled the oil drain plugs, the port side lower unit had nothing in it. There was a small bit of greasy residue that might have drooled out, but nothing more than that. The starboard side ran about a pint of pure water before the oil came out. I knew I would have my work cut out for me this spring. Incidentally, neither of these drives made any noise, and both ran and shifted fine as I went from my marina to the launch area.
So I was surprised in the fall to find no oil in the lower gear housing on the port side unit. I was even more surprised this spring when I pulled the upper gear housing cover and it was full right up with oil. And also the u-joint bellows was full of oil. Does anyone know what causes this to occur?
