- May 16, 2009
- 9,327
Re: DP290A guru's needed - leaking input shaft seals
Scott I'm happy to see your going to try a new crush sleeve even if it may not make much sense visually to do it. Jugging by your many posts of excellent advice given, I know your a man of wanting things right even if it may not make total sense at the moment. It may not even be the problem but at least you know your doing everything within your power for it to be done correctly to the best of your knowledge.
Just like to add for reference to other forum members that may read this, The quote above is how I was taught to treat this bolt, anytime it has been loosened/backed off it needs a new crush sleeve.I think that as soon as the bolt is loosened that changes the tension on the sleeve.
