Drain carbs or not
Texasmark
Well I guess we made this clear as mud for you. Sorry about that. Best of luck.
Johnson110
Got a new drain plug for carb, it has a hole in the screw for draining so you do not have to remove screw. Hey Texasmark thanks for all help, respect you for your knowledge on mercury outboards as this is my first mercury outboard!
ondarvr
If you want to get real picky, draining them is the correct method, running it until it stops only lowers the fuel level in the float bowl, it doesn't drain it, so some fuel is left in the carbs. Every time this question is asked you'll get a dozen different methods and each person says they've been doing it this way for years and have ?no problems?. What this means is that not many people have problems no matter how they do it, so find a method you want to believe in and sleep well.
My method is to turn off the key, at that point it's ready to sit for whatever amount of time passes. Been doing it that way for years, and I have "no problems".
