After changing the lower unit oil I have heard it is recommend to change the oil plug gasket and O-ring. Does this apply to new engines as well? The motor in question is a 2001 Mercury 90ELPTO. I don't remember seeing an O-ring when changing the lower oil, and if the gasket sits against the screw where does the O-ring go? Does this apply to the two vent screws as well? At $2.99 a gasket that can get expensive for all three screws. Also, someone mentioned the OMC plastic washers seal better than the Mercury fiber ones. Anyone know where I can order some from? Only ones I can find are OMC O-rings.<br /><br />Thanks for the help,
