BuzzStPoint
- May 27, 2009
- 1,003
I have to replace 2 drain tubes.
One in the splash well. And one in the transom at the bottom.
The lower drain is 1.5 inch. The splash well is 2 inch.
I see the drain tubes for inch and a half and 2 inch.
Does anyone know if those are exactly measured?
So from outside to inside is 2 inch. Is the 2 inch drain tube oversized to flare out? or do I need to order a longer size and cut it down?
