draining oil from su75 dt power trim?
outboardnut
Anyone know how the heck your supposed to get all the oil out of one of these?
boashna
Re: draining oil from su75 dt power trim?
they never need any fluid change , however this is what I would do . raise the motor up , this will make the reservoir full , it is also the time to check for proper level of fluid. the fluid in there is a transmission fluid (oil) . buy a fuel bulb and a hose and pump it out . after replacing the fluide move enging up and down several times to get the bubles out and then check the fluide with the engine up .
JUSTINTIME
some models u need to have down to get out fluid
