Draining water from block?
Rinker85
Hello. I have a 2001 5.7 L GS and we are going to get cold weather tonight. I want to drain the water from the block. I found the blue pet **** valve on each side of the engine for the manifolds but where are the drains for the block? There is brass plugs on the end of each manifold . Is that it?
thanks
yes. also drain the raw water hose going to the impeller and drain the large J-shaped hose from the water pump to the thermostat
Rinker85
Ok thank you. It looks like there is some type of sealant on the threads of those drain bolts. Do I need put that on before reinstalling?
pipe dope or teflon tap at most. I used a dab of axle grease for years
