Tafflad
- Oct 23, 2007
- 547
Putting this Q here in this sub-forum, as the drive sub forums are manufacturer specific ...
I am looking to select optimum engine & drive mix for next boat.
Which will be a 21/22' hull (Chaparral 216/226 current considerations) .... My use in in-shore salt water towed watersports ... majority of towing is in 18-26mph, acceleration and being to hold a constant speed is more important than maxium speed.
I have asked some Q's over engine on the relevant sub forum:
http://forums.iboats.com/showthread.php?t=520897&p=3520127#post3520127
to help decide on how many horses I need.
Would appreciate some advice over drives ...
I have had several Mercrusier Alpha drives ... how does the Volvo SX drive compare ?
Then the important consideration is do I consider the (not inconsiderable) extra spend on a B3 or duoprop.
If The spend is worth it ... is there a significant advantage in either B3 or Duoprop, which would then make the choice of engine for me.
