Re: Drive shaft snapped (1990 140hp)
@airman1094 I will try again with heat tonight which will also have another day of the PB soaking in. I did empty the lube.
@boobie I was thinking about trying to pull from the bolts at the back of the carrier but decided instead to rig up two U bolts to pull on the carrier from behind the support arms where the two holes you're talking about should be. I drilled a hole in the flat retainer plate of each U bolt so i could pull on them with the threaded rods i put on the puller.
This bearing carrier does not have holes to attach a puller on the face of it.
By the nature of the setup I made though it can shift around and ends up not pulling evenly and so pushing laterally on the prop shaft. I don't know how much it takes to bend it but i'd rather not find out. I did put a lot of force on it last night.
Edit:
Aha!
http://www.amazon.com/Pro-Grade-182...65702955&sr=8-2&keywords=2+jaw+puller+10-inch
Amazon Prime = $3.99 overnight shipping
Edit:
Aha!
