Re: dry wall finishing tips
I have done so much drywall in my life, I see it when I sleep.
I started out by hanging... now, I hang and tape both. I don't mind it, but like most have stated, it takes alot of practice to get good... otherwise, you'll be sanding alot. There's nothing wrong with that. You can end up with the same results by sanding a bunch, it's just dirtier, and more tiring.
And, don't even get me started on the masks. "You don't use a mask?" Yeah.... wear glasses to see, and then put on one of those frickin' masks. Good luck with that.
I agree with many. I use a 14" trowel... some use a smaller trowel, or even a wide knife, but I have had the best results with my big 'ol trowel. The longer it is, the nicer your cornerbeads look, butt joints are troweled out further, and the flats are nice and, well, flat.
I put the pressure on HARD on the outside edge of the trowel. I raise it by an 1/8 or so in the middle of the joint. It saves the sanding on the outside edges of the joints. Most bad finishing jobs are usually on the edges of the mud lines. Pay particular attention to these areas. And remember... if you get too much, it's not the end of the world. Just a little more work at the end.
V1_0: When I used our little 'bucket dust catcher', it seemed like it sucked so hard that it pulled the sander tight to the wall. It worked good, but on large jobs, it just got too strenuous. Maybe you're a bigger man (or woman) than I am.
