DT115 water cooling issue - nothing at the Thermostat
majnolo
OK I will be brief!
No water to the thermostat
Figured water pump
I dropped the bottom end and put a hose up the tube that the pump feed
Lots of water flowing back, nothing at the tstat, very weak telltale
so I took out the tube that the water pump feeds - it was bent and destroyed - unbelievable - like someone went at it with a hammer.
so I took the hose and stuck it up the hole where the tube used to be - again, water flowing all over, even out what looks like a small square exhaust port on the back of the motor extension. yes water at the telltale, but nothing at the tstat.
HELP - is my motor toast? cracked or????
my only guess is that it was not completely drained last Fall and it froze over the winter - who knows??
please let me know if you have any suggestions
thanks!
mjf55
majnolo, first, Welcome to iBoats.
What year is your Suzuki? Can you post your model number.
Is this a new to you motor, or did you have it for awhile?
Where was the primary usage, fresh or salt water.
I assume that you have removed the thermostat for your testing. Have you tried pouring water down the thermostat housing to see where it goes?
How about posting a picture or 2 of the water pump, tube and thermostat housing. I think that will give us here a start to see what is happening.
You need 3 posts to post pictures, and here is a link on how to do it. Option 3 is the best option, using a free photobuchet account.
http://forums.iboats.com/forum/forum-rules-and-guidelines/9938375-photo-upload-tutorial
majnolo
Hello mjf55
In answer to your questions
It is a 1985
Salt water use (on a 17' center console)
Pouring water in the tstat opening and water comes out the bottom
I have had the boat about 5 years and this is a new one
Have had rough running poor idling issues but never heating limp mode stuff...
99yam40
Pull the power head and look.
I do not see how water freezing would have caused tube bent and destroyed like someone went at it with a hammer.
majnolo
I agree
Looks like it was assembled wrong - the top of the tube not properly engaged when the bolts tightened
Pull the power head...
Wondering if this 1985 motor is worth the effort??
