DT5 water circuit?
ive got a DT5 0502 250762 and am concerned that it isnt pumping water.
i think i can see a water outlet under the powerhed but it doesnt have any water coming out of it.
How can i tell its pumping or not?
Re: DT5 water circuit?
should I add that Im in Australia, so being that its refered to as the land down under, maybe the numbers are too?
deejaycee_2000
according to your serial it is a 1992, but suzuki didn't make any 5hp then ....
you can try and wiggle a thin wire in the "pee hole" .....
Well the only thing that I can go on is the tag that is on the motor which says (clearly) the numbers I posted, so unless it is an older (1991) that was specifically numbered and badged for the local australian market, then I have no other ideas as to why I have a DT5 that was badged in a year when they apparently made none..........
What I think is the pee hole, is located up under the power head on the left (when looking at the motor, standing behind the prop).
Does this sound correct?
deejaycee_2000
nope, it should be on the right (when looking at the motor standing behind it), take the cowling off and have a look, a black pipe should come out the powerhead and onto the "pee-nozzle" connected below the cowling ..... you can take the pipe off and see if water comes out when running ....
