I have a dt 75, out of water, running with fresh water from earmuffs. Motor
starts fine ,idles a little rough, revs up fine for a little while and then takes off to around 4500 or so and will not come down unless I smother the air intake and then it will idle. Is this happening because there is no load on the prop or do I have some work to do?
