If your referring to the clamp on the spring package, all mine face to the rear of trailer. (i have a triple axle)
Your first picture is like mine. Maybe change the springs around in second picture to be the same as the first pic
The spring half lengths will be diff if there mounted opposite then the other side. here is a video that gives you an idea
https://youtu.be/uUepz7MDdqk
this will will tell you if the axle is parallel.
2700lbs total? Seems like a tandem is way overkill
I was thinking of chucking up the spindle in a lathe and then you'd see the wobble from the camber. It wouldn't take that big of a lathe with the tail stock removed to turn the axle. Don't turn on the lathe --- this is a hand turning process.
Your idea of making and using some offset bushings should work fine. I've used that for a miss drilled hole in a bell housing that I was modifying.
I'd shoot for 1/16th or less knowing some additional error will creep in.
