Re: Dual Battery selector positon when docking
Shaggy, When the batt switch is on both, it appears to be a single large battery to the motor. It will charge both batteries, and the motor will use amperage from both batteries to start the motor. Other settings isolate one battery for those functions.
The way you are supposed to use dual batteries is to start on the odd battery on odd numbered days(ie Batt1 on July 1,3,5,7,9...), move the switch to both for running and charging, and then when you stop the boat, move the switch to the battery corresponding to the day, odd or even. if the battery you are using fails to start the motor, the other one should be fully charged from the day before's running, and will start the motor.
Most of us do not use a lot of power while out in our motorboats, so we leave it on both all the time, ans some of us shut the batteries off at the end of the day, in the slip or trailer.
