Guys,
I am restoring a 63 starcraft holiday and I have a question. I needed to pull off the motor (73 60HP johnson) to replace the transom and when I was disconnecting the motor I noticed a red wire not connected to anything in the motor. It did have a U fitting on the end but it was just balled up in the inside of the motor. when I pulled it out with the rest of the wires (plug) I figured it wasn't used anymore. After going through all the wiring on the boat I found that this wire is connected to my tach, which was wroking the last time used the boat. The question is where is this supposed to be connected to in the motor? Any help would be great!
Thanks,
James
Thanks,
James
