tolent
- Jul 18, 2016
- 62
Ok. Here's my issue, the motor won't turn over. cleaned all contacts, installed new starter and jumped it direct still the starter's bendix engages the flywheel but won't turn it over. Got super good compression. Pulled plugs and the motor turns real smooth. The starter turns the motor smooth with no compression but won't under load. Any ideas? I ordered a new solenoid but that doesn't seem to be the issue considering I jumped the starter direct to the posts. It was recommended that I try starting using a pull rope which I haven't done yet to rule out any running issues. The boat has been sitting for almost 10 years so it might have problems I'm not aware of considering I got it free and the previous owner didn't say if anything was wrong with it. Also I made sure it was in neutral...I can spin the prop with no resistance.
