Ebay Cat filter water separators for $8.99
sdowney717
Wanted these to perhaps setup a portable tank polishing system and got them for good price.
cat 252-6338 uses a napa 3166 fram c1191a wix 33166
http://www.fleetfilter.com/filter/33166.html, under $10 per filter
So looking at these, they have a thick GLASS not plastic bowl, the sealing rings are metal for the plugs and the thread is 1/4 pipe for fittings. They also have a metal fill port - vent on the top.
The small drain port is plastic. I was also wondering if these could go in an engine room for a gasoline boat if you changed the plastic drain, tapped it for a 1/8 pipe thread and put a metal drain ****.
Any feelings about that? I had read plastic fuel bowls were not ok for gasoline engine rooms, but what about glass?
ricovw
Re: Ebay Cat filter water separators for $8.99
personally, i would stick to the cannister separator, no glass. The last thing you need is to have the glass break,and have fuel spilling into the engine bay while cutting through some chop. IMHO
sdowney717
I will use these as part of a portable setup to polish fuel.
Went to the hydraulic hose store. And got some fittings.
He says they are SAE 5, I thought SAE 4.
So picked up four SAE 5 ORB to FJIC 3/8 flare
he was out of the adapters to go from sae 5 ORB to female NPT 1/4 pipe. Which I need 2.
Tahorover
The glass bowl on my fuel pump is 65 years old and doesn't leak a drop!
sdowney717
I polished the fuel back and forth from tank to tank 5 times with these and they worked swell.
Is it better to just leave the inlet and outlet in the same tank and let it run for hours, or keep emptying one tank to fill the other and back again?
Also, you can fit a 6 micron filter into these which is longer by getting a longer main bolt.
wix 33196
http://www.fleetfilter.com/mm5/merc...fleetfilter&Product_Code=33196&Category_Code=
I found out these are used in some gasoline engine applications. From the list here
http://wixfilters.com/filterlookup/PartApplications.asp?Part=33166
These are really nice filter housings.
