Edit Avatar: Image resize failed due to inability to obtain image size.
PalmettoBotr
I'm not sure exactly. I know I was saving as 55 x 75 and such as that, but it kept trying square off everything. So I found a logo that was square and made it 55x55 pixels. That seemed to work. Still seems small.
I like your new one by the way. :)
toneeees
Administrator
There is still a weird issue with the image selection and resizing. At least everyone can now upload a custom avatar. We will keep working on it!
jbcurt00
i don't see any avatars on anyone
I just ran thru a forum category I've never been to, and a Topic I've never opened and there were avatars I've never seen showing on members I've never seen a post from. Do you see my avatar on this post? In the Topics I've read this morning, I've seen all the avatars I'm used to seeing. You don't have one shown though Joe. But I do see your Sig pix....
toneeees
Administrator
Avatars should be right above the persons username. Joe, what do you have showing above other members usernames?
Fishermark
Tony, what is your avatar supposed to be? Is it sized right? I can't tell. Here's what I see right now - (in case in changes later):
redneck joe
there is nothing above anyones name. I've never loaded one. My sig pic I loaded a few months back and didn't need to do anything for the upgrade.
Let me see if there is and settings to show avatars - there usually is for sig pics.
redneck joe
and to confirm I cannot add as well
Pic is 60x60 and 3 kb. Tried both from photobucket and local machine. .gif filetype
redneck joe
aha! saved as a jpeg and worked. Is there a list somewhere to post of allowed file types? Other forums show that when you are in the upload process.
GA_Boater
I don't think we allow .gifs as a avatar.
Toneeees, is that a change with the V5.x.x versions. Bondo and Bruce58 come to mind as having gif avatars.
Bruces -
Bondos -
toneeees
Administrator
Bruces -
Bondos -
Let me double check, I thought I saw a setting that was set to "No" for allowing animated avatars.
